Ha! I'm probably dating myself but my first train was an AC Gilbert American Flyer. A 4-6-4 Hudson steamer with five cars. It used a transformer with a rheostat and put AC on the rails. I remember sparks used to fly off of the tender wheels but that was normal. Now we have DCC or DC analog transformers with pure DC and pulse power outputs. Locomotives have either precision "can" motors or open frame with five pole skewed armatures. The locomotives of today run silky smooth with no jerking and as slow as crawling one inch in one hour without over heating. Amazing and it's all due to the Electronic Engineers of the world that are only paid enough to have a respectable lifestyle. Doesn't seem quite right, do it.
I appreciate the kind words. It's just that with the advent of the computer and Google there is a lot of misinformation out there so I prefer to keep mine as factual as possible.
Bonanza! Your schematic is perfect! It's simple enough that even I can actually build it. I really like the idea of using IR for this project. I think I'll set the led and phototransistor at an angle across the rails so they don't "see" each other through the joint in the cars and maybe aim them through some black tube to keep the IR beam from scattering to prevent any false triggering.
Last question, if you don't mind. Would 1/4 watt resistors be sufficient or would you recommend I use 1/2 watt?
I really can't thank you enough for all your help and wisdom in seeing me through to a happy ending on this project. You really did go far beyond the call of duty and I really do appreciate it!
Jack
Jack
