Subcircuit in SPICE
Discussion in 'General Electronics Chat' started by soumendu89, Jan 22, 2014.
  1. soumendu89
    Jan 22, 2014
    Moderator edit:
    This thread was split from here: http://forum.allaboutcircuits.com/showthread.php?t=27619
    Your post has been moved into its own thread, where it will draw more responses.
    Please refrain from "hijacking" existing threads with tangent or off-topic questions. You can create new threads for new questions using the "New Thread" button on the upper left of the page.
    I am trying to create a subcircuit in PSPICE and I need to include following (dependent)voltage expression between two nodes 2 and 10 inside the subcircuit as described above by unkukaracha
    E 2 10 value={(q/Ceq)*(Nsil*(exp(-2*V(2,10)*ET)-exp(V(46)))/(exp(-2*V(2,10)*ET)+exp(V(23))*exp(-1*V(2,10)*ET)+exp(V(46))))+{(q/Ceq)*(Nnit*(exp(-1*V(2,10)*ET))/(exp(-1*V(2,10)*ET)+(Kn)*exp(V(23))))}
    The complete expression cannot fit in one line due to 132 character limit, so I tried using the following technique of breaking the expression into two lines
    E 2 10 value={(q/Ceq)*(Nsil*(exp(-2*V(2,10)*ET)-exp(V(46)))/(exp(-2*V(2,10)*ET)+exp(V(23))*exp(-1*V(2,10)*ET)+exp(V(46))))}
    Yet, the simulator does not take into account the second line while calculating the voltage between nodes 2 and 10. I am using Orcad PSPICE for the simulation. Can someone help me in solving this issue?
    Soumendu
  2. tshuck
    Oct 18, 2012
    3,531
    675
    You can make a thread of your own to ask a question of your own. Do not hijack another person's thread.
    I will ask a moderator to split this off to a new thread.
  3. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Try removing the {} characters and using the + character at the start of each continuation line.
