Stupid Zero Flag question
Discussion in 'Embedded Systems and Microcontrollers' started by daredavel, Mar 11, 2010.
  1. daredavel
    Feb 22, 2010
    32
    hi guys! can you help me understand the zero flag in assembly?
    example:
    (Count = h '3')
    movf Count, W
    xorlw 3
    btfss Status, 2
    goto next
    goto next1
    How can i determine the zero flag sir if it is set or not? Sorry for the stupid question..its my first encounter with the zero flag.. thank you!!
  2. rjenkins
    Nov 6, 2005
    1,015
    69
    the instruction
    btfss Status, 2
    is determining if the Zero flag is set.
    The status register bits have these meanings:
    (Taken from a Microchip PIC datasheet)
    Code ( (Unknown Language)):
    1. bit 7 IRP: Register Bank Select bit (used for indirect addressing)
    2.     1 = Bank 2, 3 (100h - 1FFh)
    3.     0 = Bank 0, 1 (00h - FFh)
    4. bit 6-5 RP1:RP0: Register Bank Select bits (used for direct addressing)
    5.     11 = Bank 3 (180h - 1FFh)
    6.     10 = Bank 2 (100h - 17Fh)
    7.     01 = Bank 1 (80h - FFh)
    8.     00 = Bank 0 (00h - 7Fh)
    9.     Each bank is 128 bytes
    10. bit 4 TO: Time-out bit
    11.     1 = After power-up, CLRWDT instruction, or SLEEP instruction
    12.     0 = A WDT time-out occurred
    13. bit 3 PD: Power-down bit
    14.     1 = After power-up or by the CLRWDT instruction
    15.     0 = By execution of the SLEEP instruction
    16. bit 2 Z: Zero bit
    17.     1 = The result of an arithmetic or logic operation is zero
    18.     0 = The result of an arithmetic or logic operation is not zero
    19. bit 1 DC: Digit carry/borrow bit (ADDWF, ADDLW, SUBLW, SUBWF instructions (for borrow the polarity is reversed)
    20.     1 = A carry-out from the 4th low order bit of the result occurred
    21.     0 = No carry-out from the 4th low order bit of the result
    22. bit 0 C: Carry/borrow bit (ADDWF, ADDLW, SUBLW, SUBWF instructions)
    23.     1 = A carry-out from the most significant bit of the result occurred
    24.     0 = No carry-out from the most significant bit of the result occurred
    25.
    By testing bit 2 of the status resister, you find if the result of the last operation was zero or not.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    You should find that because 3 XOR 3 = 0 that it should skip to the goto next1 instruction.
    You will probably find it easier to write btfss STATUS, Z (Z and C are defined in an INC file).
    A few instructions don't affect the Zero flag, (SWAPF, RLF, DECFSZ, etc) - there is a table in the datasheets that lists the flags affected.
  4. daredavel
    Feb 22, 2010
    32
    thank you sir! it will go to 'next1' sir? not in 'next'? because the result was 0..so it will continue to the next line? if the result is 1, it will go to 'next1'? im kinda confuse..
