Stupid Arduino Powering Question
Discussion in 'Embedded Systems and Microcontrollers' started by crazyengineer, Mar 15, 2012.
  1. crazyengineer
    Dec 29, 2010
    156
    For my engineering project, I'm thinking about powering the arduino through 3 AA batteries. Is it possible to power the Arduino using 4.5V?
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Which arduino do you have? Will you use the USB interface during battery operation?
  3. vpoko
    Member
    Jan 5, 2012
    258
    47
    Most Arduinos require a minimum of 6V input (7V recommended) that's regulated to the logic level of 5V. A few Arduinos, like the Pro Mini, have 3.3V versions and require a minimum of input voltage of 3.35V.
  4. be80be
    Jul 5, 2008
    432
    57
    If you read the data sheet for the uno it can use both 3.3 or 5 volts and it has blocking diodes to keep you from back feeding the usb and the regulator.
    You can pull the chip and use it at 4.5 volts leave it in the uno board and use a wall wart you need 7 to 12 volts but it will work with 6 to 20 volts but they want you to use 7 to 12volts
    If I wanted to use it at 4.5 I would buy a ATMEGA328-PU and program the bootloader on it and use it in my project.
  5. vpoko
    Member
    Jan 5, 2012
    258
    47
    Where are you seeing this? I'm looking at the specs and see 6V minimum input voltage.
