Studying for FE: Help Understanding Laplacian Math Question
Discussion in 'Homework Help' started by al seeger, Feb 22, 2016.
  1. al seeger
    Dec 9, 2014
    13
    Hello Everyone.
    I am currently in the process of studying for the FE (Electrical and Comp) Exam.
    Trying to learn some concepts I missed in school and was hoping for some advice with the following question:
    Laplacian1.jpg The Solution is as follows:
    So far I've done little more than copy the problem. I'm just not sure where to go from there, if someone could help me understand the solution, I'd be grateful. Thanks and Best Regards.
    - Al -
  2. WBahn
    Mar 31, 2012
    18,093
    4,918
    What part of the given solution is stumping you? Do you know how to take partial derivatives?
  3. al seeger
    Dec 9, 2014
    13
    Thank you WBahn for the quick reply.
    No, I don't believe I do. However, my next step will be to learn the partial derivative procedure, if that's what you suggest.
    I'll post back later after trying that.
    Best Regards.
  4. WBahn
    Mar 31, 2012
    18,093
    4,918
    What background in calculus do you presently have?
  5. al seeger
    Dec 9, 2014
    13
    I took Cal II a few years ago. I do remember briefly going over this subject.... guess it didn't stick .
  6. al seeger
    Dec 9, 2014
    13
    Found this walk through of the solution online.
    Thanks for pointing me in the right direction by suggesting Integration by Parts.
  7. WBahn
    Mar 31, 2012
    18,093
    4,918
    Where's the x² in the denominator coming from?
  8. al seeger
    Dec 9, 2014
    13
    Correction: I meant to say "Partial Derivatives" not "Integration by parts"
    It looks to me as the denominator (x^2) is used to evaluate each part of the equation at x, y, and z
    Apparently (a*f)' = a*f' ==> 1/3 a/ax x^3
    Then apply the Power Rule: 1/3 3x^3-1 ==> x^2
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No. The differential operator
    \frac{\partial ^2}{\partial x^2} means: take the partial derivative with respect to x, and x only, twice. There is no x^2 in the denominator.
  10. WBahn
    Mar 31, 2012
    18,093
    4,918
    I'm not seeing it.
    You want the second partial derivative with respect to x of f(x). So take the partial derivative with respect to x twice.
    <br />
f(x) \; = \; \frac{1}{3}x^3 \, - \, 9y \, + \, 5<br />
    So you want
    <br />
\frac{\partial \, f(x)}{\partial x} \; = \; \frac{\partial \,\frac{1}{3}x^3 \, - \, 9y \, + \, 5}{\partial x}<br />
    <br />
\frac{\partial \, f(x)}{\partial x} \; = \; \frac{1}{3}\frac{\partial}{\partial x} x^3 \, - \, 9y \frac{\partial}{\partial x} 1 \, + \, 5 \frac{\partial}{\partial x} 1<br />
    The last two terms do not depend on x at all, and are therefore zero. The first term reduces
    <br />
\frac{\partial \, f(x)}{\partial x} \; = \; \frac{1}{3}3x^2 \; = \; x^2<br />
    Now take the partial derivative of this with respect to x to get the second partial derivative of f(x) with respect to x and you get
    <br />
\frac{\partial^2 \, f(x)}{\partial x^2} \; = \; \frac{\partial}{\partial x} x^2 \; = \; 2x<br />
    You still need to take the second partials with respect to the other two variables, but when you do you will see that nothing survives.
  11. al seeger
    Dec 9, 2014
    13
    Thank you again - this makes much better sense now.
    I hope to get some more help when I get to the circuit analysis section and beyond.
