student
Discussion in 'Homework Help' started by snake851, Mar 6, 2011.
  1. snake851
    Mar 4, 2011
    as a stedent with a below par instrutor, I am confused.On the board he showed us a 2-bit multiplier.Our assignment was to show a 3-bit multiplier via block diagram.I think I need a full adder for my 3rd output but am unsure. any help would be appreciated
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you made any attempt to work out the solution? You have posted this same thread several times. We are not a homework service:
  3. snake851
    Mar 4, 2011
    if I hadn't have made a block diagram already I wouldn't be asking for help.It's the understanding of the circuit I'm l;ooking for
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    What do you mean by 3rd output? The 3rd bit of the result? If your input is 3-bits long your result will be 6-bits long.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Go ahead and post your diagram of the circuit you have generated. Then we can comment on where you may be able to improve it.
    hgmjr
