hi
i want to use this surface mount npn transistor to switch a relay for a arduino project im building, i wast to use a so23 surface mount transistor could someone please tell be the symbols for the max current and max voltage for the base pin to work out what value resistor to use?
thank you
http://www.rapidonline.com/pdf/47-3372.pdf
thank you
