Stuck on finding the natural response
Discussion in 'Homework Help' started by p75213, Nov 22, 2011.
  1. p75213
    May 24, 2011
    39
    I am attempting this problem but have got stuck on finding the natural response to the circuit at t>0.
    When the independent current source is turned of we get a short circuit from the top to bottom. I am struggling to come up with the appropriate KCL and KVL equations.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    No we don't. Presumably you mean turned on....?
    Through which elements does the current flow at t=0+ when the switch first closes? The source will adopt whatever voltage is required to match its terminal load conditions.
    Through which elements does the current flow at t=∞?
  3. p75213
    May 24, 2011
    39
    At t=0+ i(0+)=i(0-)=0
    At t=\infty i=2
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    And - at t=0+ all of the 2A flows into the left hand branch.
  5. p75213
    May 24, 2011
    39
    For the LHS I used v(t)=v(\infty)+(v(0)-v(\infty))e^{-t/RC}
    And for the RHS i(t)=i(\infty)+(i(0)-i(\infty))e^{-tR/L}
    The result is the same as the answer given however in both cases I get the exponent = -2t rather than -5t.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    The solution is somewhat convoluted ...
    Denote the current in the left branch as i1(t) and the voltage at the top node as v1(t)
    v_1(t)=10i_1+20\int i_1 dt=4i+2\frac{di}{dt}
    also
    i=2-i_1 & \frac{di}{dt}=-\frac{di_1}{dt}
    v_1(t)=10i_1+20\int i_1 dt=4(2-i_1)-2\frac{di_1}{dt}
    leading to
    and
    \frac{di_1}{dt}+7i_1+10\int i_1 dt=4
    \frac{d^2i_1}{dt^2}+7\frac{di_1}{dt}+10 i_1=0
    Initial conditions: i1(0)=2, i(0)=0, v1(0)=20
    The real roots of the CE are -5 and -2
    So
    i_1(t)=K_1e^{-2t}+K_2e^{-5t}
    Using i1(0)=2
    K_1+K_2=2
    Using v1(0)=20 and i1 as defined above, along with the relationship
    v_1(t)=8-4i_1-2\frac{di_1}{dt}
    The values of K1 & K2 can then be found and so on ...
    As it turns out the value of K1=0 which accounts for the existence of the exponential solution being in -5t only.
    This problem is far more readily solved by the use of Laplace transforms.
  7. p75213
    May 24, 2011
    39
    Your right - it is convoluted. Haven't got to Laplace Transforms yet. That's towards the end of the book. I notice Khan Academy has included them in the differentials section. This is a good free learning resource for anybody interested.
