Stuck on Cylindrical iron-clad solenoid magnet problem
Discussion in 'Homework Help' started by Mang Ge, Oct 14, 2015.
  1. Mang Ge
    Oct 14, 2015
    Guys, Im new here but have been stuck on this question for like 2 days 5 hours till now. Pls help me out of this thing.
    a) Draw the magnetic equivalent circuit.
    b) Compute the flux density in the working air gap for x=10 mm.
    c) Compute the value of the energy stored in Wfld (for x=10 mm).
    d) Compute the value of the inductance L (for x=10 mm).
    e) For a force ffld of 1000 N determine for x=10 mm the current I=I0 required.
    Values given
    grad = 1 mm, R=20 mm, and d=10 mm. The exciting coil has N=1000 turns and carries a constant current of I=10A.
  2. Mang Ge
    Oct 14, 2015
  3. recklessrog
    Member
    May 23, 2013
    346
    102
    Sorry but I'm a little confused, looking at your drawing of the core, it shows 1000 turns, but your current is a CONSTANT 10 amperes. This would require (assuming copper wire) close to 15 swg wire (10.5 amps) 26.8 turns sqcm. So there does not appear to be enough winding window room available. Am I missing something?
  4. Mang Ge
    Oct 14, 2015
    Hi, thanks for replying. This is what this problem exactly says. But I didn't have the thought as deep as yours.:(
    The cylindrical iron-clad solenoid magnet shown in Figure 1 has a plunger which can move a relatively short distance x developing a large force ffld. The plunger is guided so that it can move in vertical direction only. The radial air gap between the shell and the plunger is grad = 1 mm, R=20 mm, and d=10 mm. The exciting coil has N=1000 turns and carries a constant current of I= 10A
