Stuck on a question
Discussion in 'Homework Help' started by cgeorge5150, Oct 8, 2009.
  1. cgeorge5150
    Oct 8, 2009
    9
    Three resistors are connected in series across 10V power supply as shown. The first resistor has a value of 1 Ohm, the second has a voltage drop of 1V, and the third has a power dissipation of 1W. Find the value of the circuit current. There are two possible answers. How do I figure this out?
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Post your answers.
  3. cgeorge5150
    Oct 8, 2009
    9
    i get two answers. since it is a series circuit current is constant.
    using R3 I=P/E 1W/10V=.1A
    using R2 10V/.1A= 10 Ohm
    VR2 is 1V/10 Ohm = .1A
    using R1 10V/1 Ohm is 10A
  4. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Why must you have two answers? Is that what the instructor stated?
    Can you tell me about Kirchoff's Voltage Law as it applies to your circuit?
  5. Ratch
    Mar 20, 2007
    1,068
    cgeorge5150,
    But 10 volts is not dropped only across R3, so that is wrong.
    Wrong amps from first calculation, so wrong for second calculation.
    Wrong on second calculation, so wrong on third calculation.
    Wrong because 10 volts is spread across all three resistors
    OK, lets get down to what works. Who cares what the two unknown resistors are? We are trying to find current. Looks to me like the best way to do that is to equate the power from the 10 volt source to the power dissipated by the resistors. So let's do that.
    T = total resistance of all three resistors, then I = 10/T
    The general equation is E^2/R = R*I^2 + I*V + 1
    The particular equation is 10^2/T = 1*(10/T)^2 + 1*10/T + 1
    Solving the quadratic gives T = 1.125178063, and T = 88.87482194
    So I = 10/1.125178063 = 8.887482194 amps
    and I = 10/88.87482194 = 0.1125178063 amps
    Ratch
