stuck in rectifying the problem in Emergency StandBy light charging circuit
Status
Not open for further replies.
bhatanilt
Joined Jul 8, 2011
Dear All.
i have attached the circuit diagram of a simple 6V standby light used as home appliances.... what happened was i have changed the battery polarity once. after that suddenly some component burned out and not working now. am stuck in trouble shooting the problem.please help me and what could be the problem for this ? what component would have burned out..??? i have changed the "fuse" (2.2 kΩ Resistor which is in series with battery) .
thanks in advance,...
praondevou
Joined Jul 9, 2011
2,942
Well it looks like, if I'm inverting the battery voltage I will have a current path through the diode on the left upper side of the 6.8nF capacitor back through the bridge rectifier on the input then through your 2k2 resistor back to the battery. So these are the first components I'd check.
However, there are not many components in this circuits so one should relatively easy be able to find out which one has burnt.
Don't measure in circuit, as it can give confusing results.
first checks:
caps - shouldn't have a short circuit
resistors - shouldn't be open or have a higher value than they are supposed to
diodes - shouldn't have a short circuit / multimeter diode tester
npn transistor - shouldn't have a short circuit / multimeter diode tester
the transformer does only have two windings, they should'nt be open, (interwinding short circuits you can't measure this way, of course)
bertus
Joined Apr 5, 2008
22,276
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
Bertus
Status
