Stuck at fault & Memories testing
Discussion in 'General Electronics Chat' started by Sarat1990, Dec 4, 2013.
  1. Sarat1990
    Dec 4, 2013
    9
    I want detailed explanation about stuck-at fault method. I couldn't get the concept. I tried to learn on google. But I still don't get it.:eek: I know! I'm not good at grasping things.:( A help in this concept is greatly appreciated.:) I just need detailed explanation. If possible please give examples with explanations. Thanks in advance for your time.
  2. loosewire
    Apr 25, 2008
    1,584
    435
    What kind of fault do you have.
  3. loosewire
    Apr 25, 2008
    1,584
    435
    When your cell phone battery go low that a fault , Believe it or not your cell phone
    battery has memory.
  4. Sarat1990
    Dec 4, 2013
    9
    I just need to know the concepts single stuck-at fault and multiple Stuck-at fault. I couldn't understand how a fault is detected using this method. I'm a beginner.
  5. Sarat1990
    Dec 4, 2013
    9
    Or gate/ NAND gate. etc.. DRAM/SRAM
  6. loosewire
    Apr 25, 2008
    1,584
    435
    If you let your phone battery discharge at certain rate all the time ,your battery
    will react to that as what you could call a fault. The battery will not last as long
    if you do not recharge it correctly.
  7. loosewire
    Apr 25, 2008
    1,584
    435
    Systems are based on energy your battery needs to be recharged ,your body needs
    food to recharge.
  8. loosewire
    Apr 25, 2008
    1,584
    435
    You are at a higher level on the fault chart , do you understand the binary system.
  9. Sarat1990
    Dec 4, 2013
    9
    @loosewire Yes
  10. loosewire
    Apr 25, 2008
    1,584
    435
    Try wikipedia ,let me know what you find.
  11. loosewire
    Apr 25, 2008
    1,584
    435
    What is your background , what level of studies do you have. What brings you to this
    question ,can you post a drawing of your question. If you do that more people will
    enter the post.
  12. tshuck
    Oct 18, 2012
    3,531
    675
    It is used to represent a fault in a digital circuit when a pin is stuck at either logic high, low, or high impedance, despite any driving circuitry behind it.
  13. Sarat1990
    Dec 4, 2013
    9
    @loosewire I'm in final year of my UG in Elecronics and computer science. I need to give presentation on testing the Memories. Basically on DRAM and SRAM cells. But the basic of digital systems testing starts with Stuck-at fault methods which am unable to get it. I really appreciate you for your time to explain me this. Please guide me further.
  14. Sarat1990
    Dec 4, 2013
    9
    @tshuck Thank you very much for your reply. Can you please explain this with simple circuit with logic gates.
  15. Sarat1990
    Dec 4, 2013
    9
    @loosewire I've read about this on wiki.. But I still don't get :(
  16. loosewire
    Apr 25, 2008
    1,584
    435
    How long is your presentation ,how big is your class your professor may not know as
    much you think. Know your class from past discussions ,study untill you are up to the
    part where you are stuck ,invite your professor to explain the question you are asking
    now. Call on a class mate to explain Tshucks, answer about the pins being stuck.
    Make a lecture how of what you want to learn, be ready to take notes if a class
    mate or professor knows more. In the mean time go back and do more studying.
    You will do two things ,learn to talk before your class on the part you know ,
    and study to learn more,you will have to do it some day. ( turning the page )
    If you have the curcuit ,keep going over it...know it well...
  17. loosewire
    Apr 25, 2008
    1,584
    435
    Look your class in the eyes ,or look over them so they know you have confidence
    up to the part you are stuck on,then you have to be creative to get your professor
    involved so he will help you and the class. Check and see if a class mate know more than
    you without breaking rules. Remember this is the beginning of your career on public
    speaking ,it take a lot to do a resume someday.You are getting a head start in
    several ways ,think about it. If you give up on me ,what the class going to think.
  18. loosewire
    Apr 25, 2008
    1,584
    435
    Give me a few lines of presentation.............
  19. Sarat1990
    Dec 4, 2013
    9
    @loosewire these are the contents of my presentation
    Motivation for testing memories
    Modeling memory chips
    Reduced functional fault models
    Traditional tests
    March tests
    March SS (Aeroflex)
  20. Sarat1990
    Dec 4, 2013
    9
    I could have attached few slides of my presentation. But I couldn't find an option to attach
