Stripping Enamel Insulation Using Solvents
Discussion in 'General Electronics Chat' started by positive8, Oct 1, 2016.
  1. positive8
    Sep 27, 2016
    38
    Hi All,
    I have hundred of short sections of enamel-insulated (or whatever coating is on magnet wire) wire I want to strip the ends of to expose the conducting wire. Is there a readily-available solvent that I can just stick the wire into to soak and dissolve the insulation? TIA
  2. Kermit2
    Feb 5, 2010
    3,845
    963
    Not really, or not quickly I should say. Some coatings are almost impossible to chemically remove, others are designed to be soldered to and will melt away when the molten solder hits it.
    I have always found the coating just needs to be broken away in the most simple means like scraping with a razor blade for small fine wire or a little emory cloth on the stiffer wire. After that is done, they will all react to the heat of the molten solder. You don't have to remove it totally all the way around, just get some clean bare copper showing somewhere and the solder just attaches and wicks under the area.
    positive8 likes this.
