Hello everyone, I am new to the forum and fairly new to electronics.
I have designed a circuit for monitoring the water level and pressure in a model steam engine. The circuit has been tested on breadboard and works perfectly.
I have also built the circuit on stripboard which again appears to work, in that the servos move when they should.
I have however found a problem when I wanted to add some LEDs to show what the circuit was doing.
When built on breadboard the output of pin 7 on ICs 1 and 3 would swing to within a few millivolts of the +5v and 0v rails, however on stripboard the output from pin 7 of IC 1 will only go as low as 1.6v and on IC 3 as low as 0.2v.
If I remove Q2 and Q3 from the circuit the outputs behave correctly. I don't think I have done anything wrong as the servos work correctly, and I can't see any bridging between tracks.
Can someone give me a clue as to what might be going on?
Stew
Stew
