Strip LED question
Discussion in 'General Electronics Chat' started by tracecom, Mar 18, 2013.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
    This is the third time I have written this post and had it fail to post, so I suppose it's that "title too long" gremlin.
    So, before I wrote the whole thing again and lost it, I posted the first sentence and then edited the post.
    Suppose I have a prefabricated strip of LEDs wired as shown in Figure A, and powered by 12 VDC. Each string of 3 LEDs draws 20 mA, for a total of 80 mA per strip of 12 LEDs. Now, suppose that the same strip must be powered by 15 VDC as shown in Figure B, but the current should not increase. I believe I could add one resistor (R9) and restrict the total current to 80 mA, but would that cause problems with the individual strings of 3?
    What is the best way to hold the current at 20 mA per string of 3 LEDs given that I cannot change the value of the resistor in each string?
    Thanks.
  2. spinnaker
    Oct 29, 2009
    5,076
    1,177
    Are just complaining or do you have a question? :)
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
    Both, but I do wonder why "they" don't fix that title length problem.
  4. timescope
    Member
    Dec 14, 2011
    298
    44
    For 15v, add a resistor in series: R= (15v - 12v)/ 80mA = 37.5 ohms instead of the 150 ohms in figure B.
    Timescope
    tracecom likes this.
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    With a power rating of 1/2watt.
  6. tracecom
    Apr 16, 2010
    3,878
    1,396
    And that doesn't violate the rule against using a single current limiting resistor for LEDs in parallel? (As you can tell, I'm a tinkerer, not an engineer.)
  7. ErnieM
    Apr 24, 2011
    7,436
    1,626
    No because each leg has a resistor so the rule does not apply.
  8. tracecom
    Apr 16, 2010
    3,878
    1,396
    Thanks to you all for tolerating (and answering) a naive question.
    Metalmann likes this.
  9. Metalmann
    Dec 8, 2012
    700
    223
    Not naive, Bro; I was wondering the same thing!;)
