Strange voltage drop on CRC filter.
Discussion in 'General Electronics Chat' started by coinmaster, Jan 9, 2016.
  1. coinmaster
    Dec 24, 2015
    357
    6
    Hi, I just built a CRC filter for a bipolar power supply and I'm getting a voltage drop I do not understand.
    http://postimg.org/image/d9yi9kcbf
    I should be getting like +/- 300v after the rectifier but I'm only getting around 170v.
    I've confirmed the AC before the rectifier is 240v.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No image there. Please include the image in your post.
  3. coinmaster
    Dec 24, 2015
    357
    6
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Why do I get an advertisment that I can skip and what is up with needing Flash Player. If you want people to help you with your problem you absolutely have to stop throwing up obstacles to us doing that. Just include the image in your post. Is that explicit enough for you or do I need to use a 2x4 to get your attention?
  5. Lestraveled
    May 19, 2014
    1,957
    1,218
    You should be getting 336 volts across your output points. Your ground is meaningless and is basically floating.
    Your second photo link works for me.
  6. Veracohr
    Jan 3, 2011
    559
    77
    I can see it just fine Papabravo, and I don't have Flash.
    Coinmaster, do you mean you're seeing +170V and -170V (340V between the two), or only 170V across the two?
  7. atferrari
    Jan 6, 2004
    2,670
    784
    Could you post the circuit?
  8. coinmaster
    Dec 24, 2015
    357
    6
    170v across the two. The voltage taken directly from the rectifier output is +/-170v. and exits the filter as +/- 170v.
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Since there is a GND symbol on your schematic, your statement about +/-300 V is incorrect. You will get approx +/-170 V. 240 x sqrt2 = 340. With a centerpoint voltage divider, that's +/-170.
    However, capacitors make horrible voltage dividers, primarily because large electrolytics can have tolerance specs of -20%/+80% or worse. So while the outside terminals probably will measure 340 V, the centerpoint will wander around with temperature, load, the phase of the moon, etc.
    ak
  10. coinmaster
    Dec 24, 2015
    357
    6
    Ah, so in order to get +/-340v I would need double the AC voltage, I'm guessing the waveform is split in half giving half the rms voltage of the AC, I have much to learn it seems.
  11. Lestraveled
    May 19, 2014
    1,957
    1,218
    Yes. Connect one of your AC inputs to your ground and you will get +336V and -336V around ground.
  12. AnalogKid
    Aug 1, 2013
    4,705
    1,300
    Expanding on that - There will be twice the voltage, but there also will be at least twice the peal-to-peak ripple voltage. No free lunch.
    ak
