Strange thing??comparator
Discussion in 'General Electronics Chat' started by nepdeep, Jan 24, 2013.
  1. nepdeep
    Sep 14, 2011
    139
    Hi, I was using comparator in my circuit for overvoltage protection...i applied the limited voltage from the function generator...performed some test of the circuit....after about 5 minutes the comparator blew....what could have been the problem...I donot see any reasons related to shorting...cause as far as i can think of i didnot touch the comparator....what could be the reasons....please help me find the bug
    The comparator has open drain ooutput
  2. debjit625
    Apr 17, 2010
    790
    186
    A full circuit diagram/schematic would be helpfull to debug the problem for us...
    Good luck
  3. GopherT
    Nov 23, 2012
    6,303
    4,021
    What kind of load was the comparitor driving? What were your input voltages and supply voltages. What part number on comparitor?
  4. nepdeep
    Sep 14, 2011
    139
    supply voltage 15......
    input voltage 0 to 3.3....and
  5. praondevou
    Jul 9, 2011
    2,936
    489
    On your diagram is marked: "both in the same package". The datasheet I has only one comparator per package.
    What was the voltage you applied to pin 3 of the upper IC?
    It must exceed than the power supply voltage.
    PS:Replace "mV" with "V".
  6. tubeguy
    Nov 3, 2012
    1,157
    197
    What type of signal where you applying from the function generator ?
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    Put a 10kΩ resistor in series with the input.
  8. nepdeep
    Sep 14, 2011
    139
    the input is 2200[mV]
  9. praondevou
    Jul 9, 2011
    2,936
    489
    So you are comparing 2.2V with 2.2V? I thought the purpose was to short the circuit on the right side of the 5k11 resistor whenever the input voltage is higher than 2.2V.
    If the maximum voltage you ever applied to the input is 2.2V I don't see a reason why it could have been damaged. Maybe there is a short somewhere.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    From post #4:
  11. Ron H
    Apr 14, 2005
    7,050
    657
    The only thing I can think of is electrostatic discharge damage. I would add a resistor and a diode, as shown on the attached schematic.
  12. praondevou
    Jul 9, 2011
    2,936
    489
    From post #8: 2.2V. :D
    Yeah I didn't see that first info.
  13. nepdeep
    Sep 14, 2011
    139
    ya the reference voltage is 2.2 v and if the input ranges from 0 to 2.2 ......so 2.2 is protection limit....next thing...i changed the comparator and is working fine now...but still couldnot find the root cause of the blown comparator...some possible scenarios....may be...!!
  14. Salaja
    Jan 27, 2013
    23
    hmm. i've an idea, but i don't know how realistic it is...
    what if, for some reason, the feedback loop wasn't stable, which caused the op-amp's output to oscillate as fast as it could, and because it is connect to the gate of a mosfet with internal capacitance, the high frequency passed through the capacitor/mosfet, shorting the op-amp output to ground. so we end up with an op-amp trying to drive 15v into ground, which only results in it pumping so much current it blows due to it's internal resistance to the current surge.
    ...is this even possible? xD
  15. nepdeep
    Sep 14, 2011
    139
    ya this is quite clever possibility...i also doubt if it is possible though....current leakage from gate to source....but i was also thinking something like that like...it was souring huge current...
  16. thatoneguy
    Feb 19, 2009
    6,357
    718
    Sometimes components are bad or counterfeit that seem to work most of the time, but not to full specifications.
    Where did you get the comparators from? There's a possibility you received counterfeit ICs. They are everywhere, and make up for a decent chunk of the "Great deals" on eBay.
