Yeah you sent me the link on that SPI problem. I took look, nothing came to mind right away but I will take another look.Could you do me a favor and post the library once complete? I'd like to port it to BoostC for the latest capabilities as well, including HC, if possible.
I do know many 8 and 16GB cards have been used in MP3 players using a PIC as the read/write to the card and feeding the data to the MP3 decoder IC. I assume they were using the microchip library.
Not entirely sure what the difference between SD and SDHC cards are, other than address bits.
Also, post what was missing in between steps aboe, such as the pin you were using, what the default was, and if you had to change the SDO or SDI pin independently?
Also, there's another guy in Embedded with a problem interfacing with SDI, though I think he is using Microchip C18 libs.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Duane Benson
