Strange op amp configuration questions
danielb33
Joined Aug 20, 2012
105
I am looking at the circuit above. Can someone explain the operation or purpose? Is this a common circuit?
To me it looks like a slew rate reducer. Lets say we have .5 V at the non inverting terminal. The gain will be one until C35 saturates. As C35 charges the current through it will lower, so the op amp will start to see the gain circuit without C35. So the gain increases again and the output will raise. But when it raises again C35 starts to see current, again. Anyone disagree with my thoughts? Thanks for the support.
Jony130
Joined Feb 17, 2009
5,488
For low frequency the circuit gain is Av1 = 1 + (R82+R20)/R19 = 222 V/V
But as signal frequency rise the capacitive reactance Xc decreases and for frequency when Xc = R82 --->Fpole ≈ 154Hz gain start to drop at rate -6dB per octave. And at Fzero = Xc = (R20+R19)||R82 -->17kHz gain will settle down at 1+R20/R19 = 2 V/V
ErnieM
Joined Apr 24, 2011
8,377
Here's a quick rule to evaluate these weird looking op amps: look at the gain at DC and infinite frequency.
At DC a cap looks like an open, so we have 220K + 1K in the feedback, 1K at the input, so the gain is 221/1+1 or 222.
At infinity the cap looks like a short so there is 1K in the feedback 1K at the input, so the gain is 1/1 + 1 or 2.
Something with lots more gain at low frequencies as opposed to high frequencies is defined as a low pass filter.
This will have two breaks, first where Xc = 220K where the gain starts to roll off, and the next at Xc = 1K where the gain levels out.
tindel
Joined Sep 16, 2012
936
Looks to me like the intent is insert a pole in the frequency response; rolling off high frequency gain when Xc=220K.
Bingo.
Not to beat a dead horse: but another way to look at it - The gain is nominally 222 at low frequency. A pole [f=1/(2*pi*c*220k)] then begins to reduce the gain... then a zero [f=1/(2*pi*c*1k)] sets the gain to 2 until the dominate pole [found in the datasheet] of the opamp begins to dominate, reducing the gain further.
You typically see these types of variable gain vs. frequency stages on error amplifiers within control loops. This particular type is especially popular when controlling inductive loads.
