Hi everyone, first time user here.
I have a reasonably good background in electronics and electrical circuits and I decided to tackle on this project:
but on a smaller scale first for troubleshooting...
My problem lies in this op-amp setup:
http://imgur.com/rMK8J8I
I will be using the LM324N Op-amp instead of the TLC274 op-amp he uses in his video. They are very similar.
The problem arises with the infra-red reciever/photoresistor signal amplifier.
As seen in the screenshot above he connects the IR's anode to the non-inverting input on the op-amp and a 10M resistor to ground (pull-down?). He then joins the inverting input to the op-amp's output which creates negative feedback if I'm not mistaken?
The things I do not understand:
1. Where are all the resistors to set the op-amp's gain?
2. Why is there a 10M resistor going from the non-inverting input to ground?
3. Should there not be a resistor between the inverting input and op-amp output?
I have include a schematic I have created to aid anyone willing to help me
Schem:
aaaaaalll the way the left
http://imgur.com/IhItULj
Schem:
