Strange Op Amp Circuit Operation
Discussion in 'General Electronics Chat' started by danielb33, Dec 22, 2015.
  1. danielb33
    Aug 20, 2012
    105
    The circuit below is part of a circuit I am analyzing.
    The non inverting terminal has 2.5VDC always.
    Note that +5VA is 5 Volts Analog - not AC.
    I am confirming that my thoughts are correct.
    The circuit operates as follows:
    1) Left node of R37 has a voltage less than 2.5V --> op amp output is D21 voltage drop above 2.5 V --> PTRAN is OFF. Circuit is isolated from Q5 collector.
    2) Left node of R37 is above 2.5V. Here the op amp will try to reduce the non inverting terminal but cant because of D21.
    This causes the output to drop to about -5V causing the PTRAN to turn on - shorting the output of the non inverting terminal to the collector of Q5.
    Any issues with my logic? Thanks for the support.
  2. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    it looks like part of a voltage to current converter
  3. Dodgydave
    Jun 22, 2012
    5,150
    769
    So what your problem?
  4. danielb33
    Aug 20, 2012
    105
    I don't have a problem....yet. I explained how it should operate if I had 2.5V at the non inverting terminal and varies voltage at the left node of R37. I just wanted to make sure my thoughts are correct.
    It is not a voltage to current converter unless I am way off. Please explain.
  5. Dodgydave
    Jun 22, 2012
    5,150
    769
    Post the full circuit then we can see what going on.
    Sinus23 likes this.
  6. dannyf
    Sep 13, 2015
    2,196
    417
    Your analysis is correct except this one: the output of the opamp would be so that the current going through the transistor is the same as the current going through R37, for the 2) scenario. ie. the output current is linear with regards to (V37-2.5)/2.2K.
    The diode provide a path for the current for the 1st scenario.
    PeterCoxSmith likes this.
  7. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    ...it looks like this type of circuit Fig 4.1:
    https://wiki.analog.com/university/courses/electronics/text/chapter-4
    dannyf has explained above...
