Strange markings on resistors
Discussion in 'General Electronics Chat' started by Gdrumm, Feb 11, 2014.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    While repairing a small Weston meter, I found these strangley marked resistors inside. Has anyone seen these type before? What is significant about the way they are marked.
    Just curious,
    Thanks,
    Gary
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    Are you sure they are resistors and not some other, caps maybe?
    Unless they are very low value precision?
    Max.
  3. Gdrumm
    Aug 29, 2008
    684
    36
    Max,
    I'm not sure they are resistors. But they look like they have been hand painted over.
    Several with same colored dots, a couple with different colored dots, and one painted jet black.
    Weird?
    Thanks,
    Gary
  4. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    It could be the instrument makers own ID's for certain tight tolerance of components.
    Max.
  5. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    I am guess makers marks too in order to speed up building processs.
  6. shortbus
    Sep 30, 2009
    4,092
    1,673
  7. Kermit2
    Feb 5, 2010
    3,847
    963
    I have seen identically marked components in older tube type two way radios.
    They are 100% certainly made with wire. Composition and winding method can create either an inductor or precision resistance.
  8. bwilliams60
    Nov 18, 2012
    734
    94
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Could be hand wound wirewound low ohms resistors. They would wind them to an exact spec, then paint, then add dots or markings. I still have some old resistance wire here on a spool somewhere.
