Strange CFL Buld behavior
Discussion in 'General Electronics Chat' started by djsfantasi, Oct 3, 2011.
  1. djsfantasi
    Thread Starter AAC Fanatic!
    Apr 11, 2010
    2,914
    881
    I had a CFL light stop working in a fixture and was replacing it. If I tapped it, it would light for a second, so I thought it might be loose, but could not get reliable operation. So I replaced it.
    When I put the old light bulb on a table, it came on full brightness! No connection to power. This seemed to last for several seconds before it finally went out.
    What gives?
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Where exactly were you when it lit by itself? If you were near a source of static electricity or other form of high voltage, it could have caused the gases within the tube to become excited and light. It is not difficult to light a CFL just by holding it in front of, say, a CRT television while it's switched on. Static electricity often appears at the front and is sometimes enough to light fluorescent bulbs.
    Der Strom
  3. djsfantasi
    Apr 11, 2010
    2,914
    881
    Ahhh... I lied :eek: I said table, but meant stairs (was thinking stairs, but seeing table - don't ask!)
    Stairs are covered with man-made material carpet, a great potential (pun intended) for static electricity.
    That might have been it. It was strange, though.
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    It is certainly possible. Synthetic cloth (or synthetic fibers that make up a carpet) could easily hold a static charge, so it would make sense that the static discharged into the bulb.
    Mystery solved?
    :D
    djsfantasi likes this.
  5. djsfantasi
    Apr 11, 2010
    2,914
    881
    Enough for me! Thanks
  6. Adjuster
    Dec 26, 2010
    2,147
    300
    I would think an intermittently connected internal capacitor in the CFL may be a more likely candidate for the mysterious energy source. If not, you had better take pretty good antistatic precautions if doing any electronic work at home. That carpet must be quite something!
