strange capacitor
Discussion in 'General Electronics Chat' started by jamus, Jul 18, 2014.
  1. jamus
    Feb 11, 2013
    54
    Does anyone know what the configuration is inside this capacitor? It is from the windings of a AC motor from the 1950's. Two wires go in, a ground lead comes out. Perhaps I should just tear it apart to find out?
  2. k7elp60
    Nov 4, 2008
    479
    69
    It might be a special configuration. The ground lead you talk about just might connect to one of the other leads. It looks like a motor run capacitor, so an
    extra wire is possible.
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    It would appear to be a dual capacitor in one case with a common ground lead. If it's from a DC motor it may be to suppress EMI from the commutator sparking and/or increase the brush life.
  4. jamus
    Feb 11, 2013
    54
    crutschow:
    Dual? It has three capacitance values on the casing
    I would like to replace the capacitor if possible. Tearing it apart didn't really give me any more clues. I will post a picture of the inside tomorrow.
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    Too small to be a motor run cap, in value and physical size.
    Do you suspect anything wrong with it before tearing it apart.
    Is this a single phase, 3 phase or small shaded pole motor?
    Max.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's a dual .075 uF cap to common ground. The third cap value (.006) is just an artifact of the cap construction, they list it on the label to be nice.
    I believe it's a brush arc suppressor like Crutschow said.
  7. Alec_t
    Sep 17, 2013
    5,976
    1,136
    It's an interference suppressor and would connect like this:
  8. jamus
    Feb 11, 2013
    54
    Thank you very much. I can get some new caps now.
  9. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    What is the reason for replacing it? did it cause a problem? It should have no effect on the actual ability of the motor to run.
    Max.
  10. jamus
    Feb 11, 2013
    54
    My problem is a mechanical one and I know how to fix it. The capacitor is 50 years old and leaking black gunk so I want to replace it.
