strain gauge
Discussion in 'The Projects Forum' started by arivalagan13, Jan 24, 2010.
  1. arivalagan13
    Apr 30, 2009
    29
    Hi everyone..
    I'm going to use strain gauge for my application.I'm going to place the gauge in a cantilever beam..one on each side of the beam..what r the considerations I need to take while designing cantilever beam?I'll apply force on this beam which will be sensed by the strain gauge..I'm using bonded metal-foil strain gauge..
    Regards,
    Arivu
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. studiot
    Nov 9, 2007
    5,005
    515
    If you are using a single strain gauge in each location you need to be really careful aligning their axis with the beam axis.
    The minimum is two gauges to get the resolution in two directions on the beam surface.
    Normal practice is to use three however to provide a check by redundant information.
  5. arivalagan13
    Apr 30, 2009
    29
    the details were useful..thanks a lot..
