Strain gauge: small or large value?
Discussion in 'General Electronics Chat' started by aamirali, Oct 27, 2014.
  1. aamirali
    Feb 2, 2012
    415
    Which strain gauge is prfeered 120 ohm or 1Kohm? Or it all depends upon the measuring circuit.
    Why 120 ohm is more common?
    Any criteria to select which value reistance strain gauge is preferred
  2. ericgibbs
    Jan 29, 2010
    2,589
    389
  3. aamirali
    Feb 2, 2012
    415
    On first link, it says prefer 120ohm if fatigue loading is an issue.
    Fatigue loading is an issue (Lower resistance wire is larger in diameter, and more fatigue resistant).
    I understand the term fatigue loading. But how does it impact the selection of 120 ohm value strain?
  4. Sensacell
    Jun 19, 2012
    1,183
    276
    Seems like another of life's ambiguous decisions, like choosing a religion.
    When faced with situations like this consider the obvious first, like maybe the 1K bridge would consume less less power?
  5. ericgibbs
    Jan 29, 2010
    2,589
    389
    hi aamirali,
    The link I posted states why high or low resistance is chosen.
    Almost all the strain gauges I have use are 350 Ohm
    E
