hello, hopefully you guys can help me i am a bit stuck and i am sure that it is something simple i am missing.
basically i want to build a circuit with a strain gauge so that i have a pressure sensitive kill switch. the strain gauge will be used to detect pressure applied to a steal rod and activate a separate circuit which will cause a engine to cut out for 75ms once the pressure has been detected. however i am having trouble finding a way to make the strain gauge circuit in to a on/off one. as i said i am sure that it is something simple i am missing.
the strain gauge is in a wheatstone bridge and is connected to a 12v dc battery however anything apart from the strain gauge can be changed to achieve the desired result. budget is a factor though
hopefully you can understand what i am trying to explain.
thanks
thanks
