Strain gage amplifier
Discussion in 'The Projects Forum' started by unborn, Mar 19, 2009.
  1. unborn
    Mar 19, 2009
    7
    Hello.
    I have done a strain amplifier using the circuit that i found on the internet. The problem here is at the output i cant get the -ve value for the strain gage. The output value will always give +ve value either i stretch or compress the strain gage. With this i attached the circuit diagram.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I don't know how you can expect to get a negative output, as you don't have a -v.
    You'll need a zero reference. You could make one by using a 10k 21-turn trimpot between +5v and ground. Use a small cap, maybe 10nF, from the wiper to ground to suppress noise.
    With no load on the strain gauges, adjust the pot until you read 0v between Vout and the pot's wiper. Then you should get + and - readings.
  3. unborn
    Mar 19, 2009
    7
    Thank you SgtWookie. Is it like this? beacuse i have tried before this to give -v supply but the strain gauges got burn.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Do you have a link to the datasheet for the strain gauge you are using?
  5. studiot
    Nov 9, 2007
    5,005
    515
    Could this be because you have connected R4 and R5 in the wrong place? As shown you have conneced a large variable supply directly across the gauge.
    Attached is a quick sketch of a revised layout, without the capacitors. This is drawn to bring out the 'shape' of the circuit more clearly.
    You need to balance the bridge with the pot, before you strain the gauge.
    Normally there are at least two gauges in this arrangement for temperature compensation and one is left unstrained. If you use this the second goes in position R2.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There is an additional constraint on such a bridge - the maximum voltage that can be continuously applied. Most often, that is 10 volts DC. That is most often +10 VDC applied and the bottom elements to circuit ground.
    It is also conventional to use an instrumentation amplifier like an INA111 to take the differential signal from the bridge. The ability to reject the 5 volt common mode voltage is quite important.
  7. unborn
    Mar 19, 2009
    7
    Thank you very much everybody. I got it.
