Hi guys -
I am writing some code that involved bit shifting, but I am getting strange outputs from my microcontroller. Save me explain whats going on, I will share my test code and results with you.
I found the answer to the 'trailing' LEDs problem (unsigned variable) but I cant seem to figure out test4()'s behaviour. Anyone shed any light to the matter?
Dan
Rich (BB code):
#include <htc.h>
#define _XTAL_FREQ 8000000
__CONFIG (FOSC_XT & WDTE_OFF & PWRTE_ON & MCLRE_ON & CP_OFF & CPD_OFF & BOREN_OFF & IESO_OFF & FCMEN_OFF & LVP_OFF & DEBUG_OFF);
void initDigitalOut() {
PORTA = PORTB = PORTC = PORTD = 0;
TRISA = TRISB = TRISC = TRISD = 0;
ANSEL = ANSELH = 0;
test0() {
int temp;
int y = 0xFF; // 11111111
PORTB = y;
__delay_ms(1000);
for (int x = 0; x < 8; x++) {
y = y >> 1;
PORTB = y;
__delay_ms(1000);
test1() {
int y = 0x88; // 10001000
PORTB = y;
__delay_ms(1000);
y = y >> 1;
PORTB = y;
__delay_ms(1000);
test2() {
int y = 0x8888; // 1000100010001000
PORTB = y;
__delay_ms(500);
for (int x = 0; x < 16; x++) {
y = y >> 1;
PORTB = y;
__delay_ms(500);
test3() {
int y = 0x7888; // 0100100010001000
PORTB = y;
__delay_ms(500);
y = y >> 1;
PORTB = y;
__delay_ms(500);
test4() {
unsigned int y = 0x7888U; // 0100100010001000
PORTB = y;
__delay_ms(500);
y = y >> 1;
PORTB = y;
__delay_ms(500);
test5() {
unsigned int y = 0x8888; // 1000100010001000
PORTB = y;
__delay_ms(500);
y = y >> 1;
PORTB = y;
__delay_ms(500);
void main() {
initDigitalOut();
// test0(); // Worked fine.
// test1(); // This worked fine. Bits shifted along nicely and the last loop outputted a fully-off PORTB.
// test2(); // This worked fine until the most significant 1 appeared... It left a trail of 1s behind it!
// test3(); // This produced a pattern of 0111100010001000, traversing PORTB, the trailing LEDs were all off this time though.
// test4(); // Same as test3. Any combination of U and unsigned didn't address this issue.
test5(); // Worked as expected. U suffix didn't seem to make a difference, unsigned did though. Tried all combinations of both.
Dan
