stp35b ?
Discussion in 'Electronics Resources' started by bomrat, Aug 27, 2010.
  1. bomrat
    Dec 13, 2009
    25
    hi i have a part that looks like a transistor that im trying to find a datasheet and a replacement for.
    the package is a to-92
    first line: STP35B
    second line: TI9210
    any ideas?
    thanks.
    also the first lead is clipped and the circuit they are only using lead 2 and 3
    and the body is heatsinked, they drilled a hole in aluminum and it stickes into that hole, like they used it for a thermocouple or something.
  2. retched
    Dec 5, 2009
    5,201
    313
    A photograph would be interesting to see.
  3. bomrat
    Dec 13, 2009
    25
    hi, here is the picture of the part
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Two leads suggests a diode. What does a meter say?
  5. KMoffett
    Dec 19, 2007
    2,584
    234
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This suggests the lead has been intentionally left off. The presence of a PN junction and some further information as to why the OP thinks this part needs replacing would be really helpful.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Could it be the part is used as a zener?
    The breakdown voltage is about 6 - 7 Volts.
    Bertus
  8. bomrat
    Dec 13, 2009
    25
    the part is only using pin 2 and 3 by design. dosen't make sence to me
    i need to find a datasheet for this so i can find a replacement part.
    i know the circuit is 5 vdc and the body goes into a heatsink block.
    its suppose to be for verifying temp. but it dosent make sence how its wired. with pin 1 not connected.
    thanks
    arlan
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  10. bomrat
    Dec 13, 2009
    25
    as far as i can tell this is what they are using this for.
    i don't have any schmatics of the circuit they are using but they use something to check the temp of that plate its mounted on and thats the only electronics that it contacts.
