I have an idea for a project. I want to power an LED or two with a solar panel. I was wondering about using two (or more) capacitors for the project. The first one to set the flash speed (a typical 555 timer set up) and a second larger one or more to hold energy to keep the flow steady, say when a cloud passes over and the sunlight isn't as strong. This is the panel I am considering http://www.harborfreight.com/15-Watt-Solar-Battery-Charger-68692.html.
Are there any projects like this on the internet? Would this even work?
