Storing data from an Arduino
Discussion in 'The Projects Forum' started by potentialeemajor, Jun 5, 2014.
  1. potentialeemajor
    May 27, 2014
    Hey guys,
    I have a project that requires up to 20 arduinos, each collecting its own data, and I need to collect all that data on one computer. I've looked in arduino to arduino i2c, but I'm not sure if it's the most efficient method. Any ideas?
    On a side note, if the i2c is the best method, I wasn't sure how to combine the code for my circuit and the i2c code. In my case, the slaves are the writers and the master is the reader. I have the master code, but I'm having trouble with the slave code.
    This is the code for my circuit:
    Code ( (Unknown Language)):
    1.
    2. #define inPin0 0
    3.
    4. void setup(void) {
    5.
    6.   Serial.begin(9600);
    7.   Serial.println();
    8.
    9. }
    10.
    11. void loop(void) {
    12.
    13.   int pinRead0 = analogRead(inPin0);
    14.   float pVolt0 = pinRead0 / 1024.00 * 5.0;
    15.   Serial.print(pVolt0);
    16.   Serial.println();
    17.
    18.   delay(100);
    19.
    20. }
    21.
    22.
    23. Can I incorporate it with the i2c code as follows?
    24. #include <Wire.h>
    25.
    26. #define inPin0 0
    27.
    28. void setup() {
    29.
    30.   Wire.begin(2);
    31.   Wire.onRequest(requestEvent);
    32.
    33. }
    34.
    35. void loop() {
    36.
    37.   delay(100);
    38.
    39. }
    40.
    41. void requestEvent()
    42. {
    43.   Wire.write("1");
    44.   int pinRead0 = analogRead(inPin0);
    45.   float pVolt0 = pinRead0 / 1024.0 * 5.0;
    46.   Wire.write((byte)pVolt0);
    47.
    48. }
    49.
    Thanks ahead of time!
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    http://www.dataq.com/
    Here's about the cheapest DAQ card you can get.
