Hello!
I've got a question (or two) about storing capacitors properly. I could not find a definitive answer, so decided ask to the experts:
The "Back Story" is:
Where I used to work, we serviced the capacitor banks for power factor correction on the 13.2kv distribution system. We always stored the spare capacitors with grounded copper bus bar sections or bleeder coils bolted across the terminals. I never gave it much thought, assuming this was to keep the potential at zero while stored & handled. They were stored in the substations, so eddy currents were, indeed, strong. (A volt-tik could ring just by walking into the stations.)
At home, I have a few (much smaller by comparison) old Mallory capacitors labeled from 1750 MFD to 95,000 MFD. (15 to 140 volts). They have been stored in a container on a shelf and have not been touched for more than 10 years.
Today, I decided to test them. (Why?)
By instinct, before touching one, I put my alligator clamp resistor of 10k ohm 20 watt across the terminals. I got a spark and the resistor warmed noticeably in the few minutes I kept it clipped on. I tried the others with similar results on two of them. Knowing me, they were bled to zero before storing.
The big question is:
How did they get this charged?
The room is an unheated 'cold room' adjacent to my basement. The storage container is plastic, but sitting on a non-gorunded shelf (if any of that is pertinent). No terminals were touching anything in storage. Are the small eddy currents surrounding us able to charge these over time?
Question Two is:
Should I store these shorted with a wire (or resistor)? Will that harm them in the long term?
Thanks for your ideas!
Paul
Question Two is:
Paul
