stops working when its soldered
Discussion in 'The Projects Forum' started by circuitBoy818, May 14, 2014.
  1. circuitBoy818
    Dec 13, 2013
    8
    I've been working on a discrete op - amp for my project. It works fine when its on a breadboard, but when i solder it, it stops working. I've built the same thing three items now, and same thing happens. I know that the connections can't be wrong. Does this have to do with the extra capacitance that the breadboard has that the perf board doesn't? which is helping the op amp work better. I can't seem to figure out what the problem is. Any suggestion would be helpful.
  2. shortbus
    Sep 30, 2009
    4,092
    1,673
    Solder bridges on your board?
  3. wayneh
    Sep 9, 2010
    12,379
    3,232
    An extra set of eyeballs might see something you're missing. In my experience the thing you "know" is right is usually where the error is.
    Anyway, how about a schematic and a photo?
  4. kubeek
    Sep 20, 2005
    4,687
    805
    Could be ESD, could be too much heat, could be bad solder joints or bad board design. Like wayneh said, post a schematic and clear photos of the board.
  5. w2aew
    Member
    Jan 3, 2012
    219
    64
    ...or it could be oscillating. We need a schematic, photos, and a description of what it is supposed to do...
  6. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    My bet is on you overheating the ic when soldering. Assuming "doesent work" = dead
  7. #12
    Nov 30, 2010
    16,670
    7,314
    That was my first thought. Capacitance in the right place can stop it from oscillating. Capacitance in the wrong place can make it oscillate. Even some tiny little pfs of capacitance can make all the difference in certain critical positions.
    Schematic and photo, please.
  8. DC_Kid
    Distinguished Member
    Feb 25, 2008
    641
    9
    solder in a IC socket, then plug the IC in.
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    90% chance there's a mistake in your soldered version. :)
  10. Ramussons
    May 3, 2013
    562
    92
    incorrect counting IC pin numbers.
    Ramesh
  11. DC_Kid
    Feb 25, 2008
    641
    9
    its a 8pin DIP package? soldering each pin just once?
    1) what type and wattage iron?
    2) how long does it take for iron on pin to make the solder flow?
    3) what type of board is it?
  12. Ramussons
    May 3, 2013
    562
    92
    Start here!
    Ramesh
  13. Blackbull
    Jul 26, 2008
    70
    6
    I was hoping the OP would come back on this one, I had the same problem and never did find a solution in spite of successfully making several of the same circuit some years before.
