UncertainPrinciples
- Joined Oct 2, 2014
- 4
Reviving a dead horse, but I wanted to say that this helped my problem.Use this with a 100 nF across the motor terminals (right on the motor). Also make sure you have good ground connections to a common grounding point near your power supply. Isolating grounds means you have floating signals to your H-Bridge. That is not good.
Also, add a ceramic 100 uF in parallel with each cap shown.
You can see my scope traces before and after in this thread:
http://forum.arduino.cc/index.php?topic=366489.0
