stop DC motor
Discussion in 'General Electronics Chat' started by firend, Oct 29, 2012.
  1. firend
    Feb 18, 2012
    44
    I am controlling a DC motor. I use L298 to control. I want to stop motor by not provide power for motor. but time to motor stop is long.
    who do anyone have idea to stop motor faster?
    thanks in advance.
  2. nsaspook
    Aug 27, 2009
    3,011
    2,354
    firend likes this.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet for the L298 shows "Fast Motor Stop" when both inputs are high or low at the same time.
    firend likes this.
  4. Adamf001
    Member
    Sep 5, 2011
    67
    alternatively if you apply an apposing current to the motor you are effectively applying magnetic brakes to the motor
    firend likes this.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    Stopping a DC motor requires applying a reverse current. This can be implemented with an opamp and current driver in the form of a "negative resistance" circuit.
  6. nsaspook
    Aug 27, 2009
    3,011
    2,354
    You can have every effective braking with just motor shorting. I easily got within a few QEI counts of the position set-point just using fast relays to drive or short the motor.
    http://flic.kr/p/dnGBPC
  7. firend
    Feb 18, 2012
    44
    i buy a second-hand motor. it has a encoder HP Q9898, a disk.on the disk has seri 02276-20014-1 and 504, made in USA.
    what does anyone have information encoder HP Q9898 and motor?
    i am sorry because my english isn't good.
    thanks.
  8. KMoffett
    Dec 19, 2007
    2,584
    234
  9. ScottWang
    Aug 23, 2012
    4,925
    777
    Free running to stop the motor, that can be use at motor with gear.
    If you want to stop the motor without gear, maybe you can add a stopping control circuit for a short time as 1/10 Second to reverse the voltage to the motor, I'm not sure how long the motor is continuing to run after power off, so you can adjust the time to suit your need.
    Maybe you can use NE555 and some logic gate to control.
    firend likes this.
  10. JohnInTX
    Jun 26, 2012
    2,393
    1,051
    My favorite way as well. You can also just put a resistor across the motor leads. Its not as good and more power intensive but its simple to drive and sufficient in some cases. Pick a value that's a balance between power dissipation and deceleration.
