stop chattering
Discussion in 'General Electronics Chat' started by bastion, Feb 28, 2013.
  1. bastion
    Feb 28, 2013
    5
    I am new to electronics and I know there must be a solution to my problem.
    I have a contact switch that though an acuatar when it makes contact it starts a boiler up for central hearting. The contact when it get close to closeing it chatters this is messing up the boilers PCB by giving it a doggy supply in the first second. Is there some thing electronic I could put in the feed to the boiler from the contacts that would stop this from happening (the voltage is 240v AC).
  2. praondevou
    Jul 9, 2011
    2,936
    489
    A solid state relay maybe? Depends on how much current you need.
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    Increase "actuator" speed to decrease switching speed?
    Slow switching speed can also destroy the contacts fairly quickly. Arcing causes pitting/carbon buildup,etc.. Switch fast.
    But yes not sure why you must use an actuator of sorts.. Just remove the actuator and use that signal to energize a relay instead or whatever.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    I think you might need to add some hysteresis to the system. Can you provide a circuit diagram of some kind and indicate which portions you can tinker with?
  5. bastion
    Feb 28, 2013
    5
    Can't control the actuator speed as it's fix to a three way motorized valve. This stops the boiler from cooking it's self i.e. full heat with the valve in a bypass mode water not going though the boiler.
  6. bastion
    Feb 28, 2013
    5
    Only the lead from the contacts
  7. bastion
    Feb 28, 2013
    5
    Would a "snubber" be the right thing to use?
    If so how do I woke out what value one to use?
  8. bastion
    Feb 28, 2013
    5
  9. mcgyvr
    Oct 15, 2009
    4,791
    976
    Why not simply use the valve control voltage/signal to directly trigger a relay eliminating the limit switch all together.
    or buy a limit switch with a lesser "chatter time" or contact design to eliminate chatter.. This is one reason some switches cost $20 and some cost $500+..
  10. BillB3857
    Feb 28, 2009
    2,402
    348
    It sounds like the "snap action" of your switch isn't "snapping". You should be able to feel it if you move the actuator manually. You need a new switch!
  11. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    use a delay on timer set for a couple of seconds
    bastion likes this.
