I have a 12 volt dc motor with a simple circuit for DC Motor speed control ( Pulse Width Modulation). The motor is driving a table on a linear rail. I would like to create switch that would stop the table moving once a switch is hit. I would also like the switch turn off a 110 volt AC Solenoid.
Event Sequence
Event Sequence
- I press start.
- The table move and the solenoid is activated.
- The table will hit a switch.
- The dc motor stop moving the table and the solenoid is deactivated.
- I return the table by hand to start. (or by motor)
