stk433-060 help
Discussion in 'The Projects Forum' started by lacko123, Mar 19, 2012.
  1. lacko123
    Mar 19, 2012
    hello i have found this amplifier with allready original circuit board on it but i have problem with connecting it.
    I take it from old sony line.
    here are the pinouts from the board
    1 overload
    2 amp stby
    3 in l
    4 gnd
    5 in r
    on the other side
    1 pa-gnd
    2 hi- out- r
    3 low -out - r
    4 +vh
    5 -vh
    6 low out l
    7 high out l
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    well . did u found a way ?
  3. DickCappels
    Aug 21, 2008
    2,753
    665
    Some guesses:
    1 overload Overload Indicator Output
    2 amp stby Standby Indicator Output
    3 in l Left Channel Audio Input
    4 gnd Audio Ground (audio return and shield)
    5 in r Right Channel Audio Input
    on the other side
    1 pa-gnd Power Amplifier Ground
    2 hi- out- r Connect your Right Channel Speaker between pins 2 and
    3 low -out - r and pin 3 -probably a bridge output.
    4 +vh
    5 -vh
    6 low out l Connect your Left Channel Speaker between pins 7 and
    7 high out l and pin 8 -probably a bridge output.
    Anybody have a more educated guess?
