Make sure that you got the "IN+" and "IN-" connections correct on the last opamp - if they are swapped, you will get an ON to OFF. To get rid of the choppiness, decrease the value of the first capacitor.Well, that circuit takes my motor from on to off (and it is really choppy as it does so). This is really frustrating.
The inverting/non-inverting inputs. Looking at my diagram, it appears that I reversed them.Are you referring to the voltage supply or the inverting/non-inverting inputs?
Which circuit are you using now? I got lostI checked some wires and had mixed things up, and it works. However, just like every other op-amp solution I've built, I can't get the voltage to the motor to go much higher than 3.75-4V. I powered the op-amp with 12V to increase the voltage to the gate and connected the motor between drain and a 6V supply. Still, it never got any higher. Why?
What voltage do you measure on the mosfet gate, drain, and on the 6V supply once the delay time has passed?I can't get the voltage to the motor to go much higher than 3.75-4V. I powered the op-amp with 12V to increase the voltage to the gate and connected the motor between drain and a 6V supply. Still, it never got any higher. Why?
The resistance across the FET is approximately zero when on, so my guess is that your power supply can't supply the needed current.I powered the op-amp with 12V to increase the voltage to the gate and connected the motor between drain and a 6V supply. Still, it never got any higher. Why?
The difference will be trivial, except for the 50k resistors, which will have NO difference!Oh, and I made a few substations. I don't have any 500k, 16k, or 50k resistors, so I went 470k, 15k, and 50k resistors, respectively. I don't assume that makes a huge difference...?
by Duane Benson
by Duane Benson
by Aaron Carman
