Still a bit confused
Discussion in 'The Projects Forum' started by meestahelectro, Aug 15, 2006.
  1. meestahelectro
    Aug 10, 2006
    28
    Hi. I continue to read, but a still a bit confused. I attached my 3v baterry to my breadboard circuit and used some jumpers to complete the circuit. when I measured the voltage, I got a reading of around .3 volts... this surprise me greatly and couldnt understand it.
    I then attached my 2.6v LED into the circuit and lo and behold the voltage going into the LED was 2.7v and the voltage out was 0 (ok I now understand why it is 0), but dont get why the voltage is so low with no component in the circuit.
    thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you post the circuit and indicate what points you are using to measure the voltage?
  3. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Not enough info. Check for Shorts or Open circuits. Need Circuit.
