I dont care so much about efficiency resistance for this mosfet, just something affordable.
These are both TO-220 packages, MXP4004AT, STF40NF20
Is there something that will just work that is common?
Here is that datasheet STF40NF20
http://www.st.com/web/en/resource/technical/document/datasheet/CD00150592.pdf
And also for MXP4004AT, is there a common cheap equivalent?
http://www.mir-power.com/mnk/uploadfile/2012-2/2012211331291.pdf
These are in Schumacher XI75DU inverters 750 watts. I got a broken lot to fix and cannibalized one to fix another. Plus there are 2 more with totally different insides but the same appearance on the outside.
