Ste's Robot Project - Motor and controller selection help
Discussion in 'The Projects Forum' started by Ste_Mulv, Sep 23, 2009.
  1. Ste_Mulv
    Sep 23, 2009
    7
    Hello all,
    I have been planning to build a robot for ages now. I have drawing "cigeratte packet" designs for literally years, but although I am good in some areas, I am hopeless at actually picking a product off the shelf and getting a circuit going.
    I am going to finally take the plunge and get buying components to build with.
    I have a few questions in this topic (which i know is taboo, but they all lead on from each other)
    I intend to build a modular system, where a module is responsible for a specific area's control, these modules will then be linked with a serial bus communication newtork (probably a long time in the future!)
    So every journey must begin with a first step, and mine is the motors and motor control module.
    What type of motor should I choose? I am thinking that a brush/brushless DC motor is the best choice to start with. I plan to strip this out of a portable car compressor pump (£7.99 from ebay). Will this be a DC Br/BrLess motor?
    What type of feedback system would be best? I think that adding an encoders to gain a feedback, thus creating my own servo and design a PID to run it all. Does anyone know of some good position encoders, that are avalible off the shelf?
    Would you just shell out and buy a servo?
    I don't want to build my own H-Bridge, because I want an all in one package that does all the options i could build anyway, however, there are millions around. Does anyone have a suggestions of a controller they have used?
    Additional transistors? will I need to add transistors to allow max unregulated current to flow to the motor, or do controllers have those built in?
    So to summerise:
    Will it be a DC Brush/Brushless motor in a car compressor?
    Is that the right choice of motor for my project?
    Are there some good position encoders avalible which will work with the above motor?
    What H-Bridge controllers are good, cheap and readily avalible?
    Will that H-Bridge come with "everything I need"?
    Thanks for you time, and any help would be much appriciated...
    Regards,
    Steve Mulvenna :)
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It would help to know what your application for this motor is.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With no parameters, not much accurate input is possible.
    One thing can be answered -
    Nope - just pull in a relay and let the contacts pass the current.
  4. DieselPower
    Sep 24, 2009
    Fanuc 0S or 5S series motors off ebay with one of jons servo amps??? (http://jelinux.pico-systems.com/motion.html) How big are you going? Robotic arm, hexapod, crawler???? Toy or tool??? I love robotics, but only if they involve welding hundreds of pounds of steel together, use massive anounts of power, and perform a needed function when done!
  5. Ste_Mulv
    Sep 23, 2009
    7
    Hey there, sorry about being ambiguous...
    I am going to make a little bot, track driven approx 30cm long and 20cm wide.
    stage one is to get the base together with the tracks and motors running and controllable with speed and direction. I would like to at this stage add in a PID and gain precice control over the speed and angle of the motor.
    I guess that the whole thing is going to weigh around 5kg, and I would like it to have a top speed (on the flat) of 8-10mph (not really fussed about the top speed though).
    <quote>Nope - just pull in a relay and let the contacts pass the current.</quote>
    I am sure that the best way to control speed is with PWM, and a relay would not be suitable for the high frequencies required... I have just checked and the quickest response time i can find is 7ms and that would play havock if I was to use a 10kHz PWM frequency
    Thanks again...
    Ste
  6. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  7. Ste_Mulv
    Sep 23, 2009
    7
    Hi again,
    this is the type of motor controller that I want, but I don't want to build one out for discrete components.
    I have heard that there are ready build IC that controlls the motor speed and direction based on the duty cycle of a PWM input. (10%DC = full reverse, 50%DC still, 90%DC full forward - DC Duty Cycle)
    I have been having a look, but there are too many to choose from, and I don't know which one will do the job.
    I have attached a flow diagram that may clarify what I am after:
    Recommendataions on the motor controller would be great
    Do I require a transistor arrary to get enough current to the motor?
    Cheers
    Stev
  8. Ste_Mulv
    Sep 23, 2009
    7
    Alberto,
    That is 100% perfect, I have been trawling through data sheets for ages now, and when I find one that looks ok, it is normally too expensive.
    This one is both in stock and reasonably priced. also example circuits in the data sheet are good.
    Thanks a lot.
    I will now be researching LIN bus controllers, LIN bustransevers and simple microcontrollers...
    Thanks again.
    Ste
  9. BMorse
    Sep 26, 2009
    2,675
    234
    Try the LMD18200T by national Semiconductors >> http://www.national.com/mpf/LM/LMD18200.html << I use this in plenty of robotics and motion control, the LMD18200 accommodates peak output currents up to 6A. An innovative circuit which facilitates low-loss sensing of the output current has been implemented also so you will be able to tell when the motors stall, it only requires a TTL compatible input for Brake, Direction and PWM.....
    I used this H-Bridge to develop a 2 speed PWM driven PM DC Motor controller (for this company http://www.Kansmacker.com) for their automated recycling machines. I also use another variation of the same H-Bridge without the current sense output the LMD18201T....
    My .02
