Stereo started smoking!!!!!!!
DerStrom8
Joined Feb 20, 2011
2,390
I have good news and bad news. Good news is that i found out what the problem is. Bad neas is is that it's a burnt resistor and i dont know what value it is
Chances are the resistor burned when the power supply failed. I'd look for more--a resistor doesn't just burn up for no reason. Keep looking for blown capacitors, fried traces, popped transistors, etc.
EarlAnderson
Joined Nov 13, 2011
166
Well, the upper limit on "one hell of a time" is the $15 manual I linked to. Looking better every moment?
+1 on that resistor NOT being the root cause, btw.
Yeah i was looking at the power supply board and it looks pretty dirty on the bottom. And as much as i hate to do it, im gomna have to buy that $15 manual
30,795
Where is the post where the make and link was posted? I must be losing my marbles or mods are playing tricks on us.
What is the make and model?
wayneh
Joined Sep 9, 2010
17,498
My bad. I may have confused this with the Sony thread. More rum and lime for my friends, it's raining buckets here for the first time in months!
wayneh
Joined Sep 9, 2010
17,498
That's one roasted resistor!
In the final photo, is that blue wire possibly shorted to the cap terminal?
Those transistors on the heat sink look to me like someone other than Sony has been working there. All that thermal paste doesn't look professional. Not that this helps you.
EarlAnderson
Joined Nov 13, 2011
166
I don't know. are you talking about the two blue wires in the top right hand corner, the wire to the left of that, or the wire on the far left
R!f@@
Joined Apr 2, 2009
9,918
Ur amp is like a haystack, can't make which leads to where.
U can start by checking for shorted diodes and transistors.
Do u know how ?
R!f@@
Joined Apr 2, 2009
9,918
Okay then find a diode, two or three will do.
I'll show u how to test them.
And post a photo with diodes and ur multimeter. So I know what I am dealing with
R!f@@
Joined Apr 2, 2009
9,918
My mistake..go thru this
The meter reading will never show zero as stated in the first pictures. If u get 0V then the junction is shorted.
Any voltage outside the range 0.4V to 0.7V is not considered correct in forward bias connection
EarlAnderson
Joined Nov 13, 2011
166
so basically I just put the positive lead of the multimeter on the P-type material and the negative lead on the n-type
