I have 2 separate units.
1) A PC stereo sound card unit (Audiotrak Prodigy HD2) with 2 outputs that feed into the inputs of a
2) stereo preamp/amp unit (model HK3480).
I would like to know if the DACs are being used on both units.
My assumption is that the PC Sound card uses its DAC and then that analog signal goes to my preamp/amp unit. At this point...would the HK3480 just amplify the analog signal that had already been converted by the PC soundcard? So I would be effectively bypassing the DAC on the HK3480?
Sorry I could be horribly wrong as I am quite inexperienced with electronics.
