Stereo Preamp
Discussion in 'The Projects Forum' started by Wendy, Dec 6, 2015.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    Just doodling with an eye towards building something like this. I would probably use the dead bug technique if I did. It would be used on my lappie or similar for microphones. Low power and small size is a must.
    So I'm throwing it out on the forum and see if it sticks.
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    Nice!
    Do you have any particular Op Amp in mind?
    How would the power-part of the circuit look like, if you want to put it in a car, and use the cigarette-lighter as a power source? More caps?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Main application is for the laptop. I need to work on training my voice, and the several microphones I have for the use are too quiet.
    The NJM4565 is a good pick for this. I have several in my storage.
    absf and nerdegutta like this.
  4. k7elp60
    Nov 4, 2008
    478
    69
    Why do you want to invert the audio?
  5. Lestraveled
    May 19, 2014
    1,957
    1,217
    Wendy
    A year ago I designed a mic preamp for my grandson. He wanted to record audio to his laptop but the mic level was too low. It runs off of 5 volts from the USB port. Here is the circuit.
    I made a PCB for it. Tested and works great.
    I have several spare boards. Interested? How is your surface mount soldering skills?
    absf and Wendy like this.
  6. Johann
    Nov 27, 2006
    190
    30
  7. Johann
    Nov 27, 2006
    190
    30
    Perhaps you should add at least a volume control and maybe some tone adjustment?
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    Note that Les's centerpoint ground is a) 100 times lower impedance; and b) AC decoupled. Without the decoupling there will be significant crosstalk between the two audio channels.
    ak
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not that want to, it just does not matter in the real world. I have two amps, I need two amps, so I used the minimum parts configuration.
    Because for this application I do not need them. Remember, size and low power is a requirement.
    I don't think cross talk in this configuration is going to be an issue. With a gain of 10 and audio frequencies, it won't be a problem.
  10. marcf
    Member
    Dec 29, 2014
    149
    20
    Wendy:
    I assume that the 5, 3v cells are CR2025's or similar. Why not use 6 of them and put 'signal ground' between the 3rd and 4th one.
    Would also make the opamp 'happy' that it is working with a real split supply. ...+/- 9v.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not a bad thought, but I generally like using virtual grounds. The power supply runs down for both sides equally.
  12. GopherT
    Nov 23, 2012
    6,300
    4,020
    The quiescent current of your op amp is 4mA. There are many op amps available with similar specs and much lower quiescent current (0.2mA in this one - giving 20x battery life - most of the time you are not likely testing your voice so current consumption is likely mostly based on quiescent time).
    This one is very close to your current op amps specs. A pretty good battery savings if using two op amps.
    I do like the idea of not adding an extra op amp to make a virtual ground and splitting the batteries to make your split supply.
    https://www.fairchildsemi.com/datasheets/FA/FAN4174.pdf
  13. Veracohr
    Jan 3, 2011
    559
    77
    A gain of 10 for a mic preamp is pretty low, is that really all you need?
  14. wayneh
    Sep 9, 2010
    12,368
    3,224
    You may want to verify that there is no software solution. Here's my experience: I've played around with plugging my guitar directly into various computers, and in general it doesn't work because the signal is just too low. BUT, with software meant for this application, I can get pretty good results without any preamp. I believe the software can increase the gain of the computer's built in amp beyond what is normally available in the system settings. This experience is on a Mac, mind you, but might have a parallel on whatever you're using. Just something worth a look.
  15. marcf
    Member
    Dec 29, 2014
    149
    20
    The virtual ground (signal ground) is developed by the two unbypassed 1meg resistors R1 and R2. U1 is shown for the power supply connections. And U1a and U1b are the same device, showing the signal connections.
    The op amp is developing a 'virtual ground' at pins 2 and 6
    Does any one else think the term 'virtual ground' is a little odd in this context?. I like 'signal ground' as it is just another ground, like 'digital ground'. There is really nothing 'virtual' about it. The "-" input of a op amp is at virtual ground.
    I think that the existing signal ground circuit, R1 and R2 is a little 'light' and at the very least should be bypassed.
    Also a split supply would require a double pole switch, which could add a little cost to the project.
  16. Lestraveled
    May 19, 2014
    1,957
    1,217
    The bias resistors (R8+R9) are there hold the Vcc/2 voltage on the 10uF cap. It is the cap that creates the low impedance virtual ground. If the cap was not there then the current from the op-amp feed back would drag the virtual ground around, causing distortion and odd gain instabilities. The cap is the important part (not the resistors) and should be sized based on the resistance of the feedback resistors and lowest frequency. Actually in my circuit the decoupling cap (10uF) is too small for a 20 Hz signal with a 412 ohm feed back resistance, but it wasn't designed for a sub-woofer.
    Edit: The above is true in a non-inverting op-amp design only. (The design I used.)
  17. marcf
    Member
    Dec 29, 2014
    149
    20
    Sorry for the misunderstanding.
    I was remarking about the circuit in post 1.
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yes, the inverting input is called a virtual ground. You will find in electronics that many different configurations can be called the same things, just as a circuit can be used many different ways, each with its own name.
    Creating a Virtual Power Supply Ground
    Wendy's Index
