I working on this project which I am using a transceiver to transmit analog signals generated from the signal generator. I am planning to use the external MIC connector to connect the signal generator to it with the help of a stereo plug cable with the other end as a pair of crocodile clips to clip to the signal generator. But the external MIC connector is meant for stereo plug cables. So my question is to ask what should I do with the extra third cable of the stereo plug cable cause my signal generator only require two cables (for the signal and ground)?
Regards
Regards
