Dear All,
I recently ripped apart an old Sony Stereo system I had. I also just built a new computer, but I have no speakers for it. Although the Sony system is pretty old, I'm sure the speakers are of decent quality. I am hoping to build my own amplifier system and hook the speakers up to my computer.
I plan to connect the audio out of my computer to my amplifier by using either a male-male 3.5mm jack (like those used in aux inputs), or a 3.5mm to RCA cable. Not sure if one is better than the other, but they both look to do the same thing.
I'm only looking for a simple amp, with an on/off and volume/gain control (using a potentiometer). I've attached the PDF of the Sony speaker. It says that the stereo system outputs 2.3W to each speaker (3.2Ω). I'm also hoping to re-use the amplifier inside the stereo system. Although I've read 2.3W is very little for a speaker, and I'm sure there are better amplifiers out there nowadays, I want to give it a try and see how the speakers sound. If they are horrible, then I will re-design it with better a better amplifier. Everything will be run off 9V.
I am planning to build the simple amplifier shown here:
http://www.electronica.ro/audio/LA4597.shtml
This looks similar to what is inside the Sony stereo system as well. I'm curious as to whether I need a pre-amplifier, and where I would put a potentiometer for volume/gain control. I'm also curious as to what type of amplifier this is (Class A, B, AB, D?) and if this amplifier sucks...why? Would it be possible to choose better cap values in order to make this amplifier better? I don't really know how to perform those calculations.
Ideally, I'd like something small like this: http://www.8audio-mall.com/servlet/the-490/Tripath-TA2024-Stereo-Power/Detail. I am by no means an audiophile, so I don't need or want something amazing. As long as it does not sound horrible, I will be OK with it. I usually use my headset anyways, but thought it would be a cool little project.
Thanks,
Philip
Thanks,
Philip
