Stereo amp pot question
Discussion in 'General Electronics Chat' started by Razor Concepts, Feb 12, 2010.
  1. Razor Concepts
    Thread Starter Active Member
    Oct 7, 2008
    212
    Here is the stereo amp in question:
    http://electronics123.net/amazon/datasheet/k115v2.pdf
    How does the single potentiometer control the volume for both left and right signals? Is that a special potentiometer that is like two pots built in to one, and are electrically separated?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Yes, its like you have two pots in one package which can be adjusted by the same knob as to have almost the same output voltage.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Pot1 is a dual ganged log pot.
    It's two pots linked together on a single shaft.
