Stepping down DC
Discussion in 'The Projects Forum' started by Beno_the_novice, Nov 7, 2014.
  1. Beno_the_novice
    Nov 7, 2014
    Hello all, I'm new to electronics and find it pretty intriguing. I've got a little project I need help with and that is taking a 12vdc (car battery) and stepping it down to 3vdc at a high current (variable between 30-70amps) can anyone point me in the right direction or to some material to read. Thanks in advance.
  2. antonv
    Member
    Nov 27, 2012
    149
    27
  3. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Welcome to the forum!
    If you're new to electronics then building your own DC-DC converter would be a major challenge, probably frustrating, and more expensive than simply buying one. I'd recommend you cut your teeth on a simpler project.
    wayneh likes this.
  4. Beno_the_novice
    Nov 7, 2014
    Yeah I thought so too and thanks for the links too that's what I'm after
